pulseConverter.countBeforeChange |
Indicates the value of the Count property just prior to the most recent write to the Adjust_Value property. If no such write has yet occurred, this property shall have the value zero.
A propriedade countBeforeChange do objeto pulseConverter pode ser lida e escrita utilizando um tag normal (IOTag).
pulseConverter-<endereçoDoObjeto>.countBeforeChange |
<tipo> = 24 |
<propriedade> = 178 |
