pulseConverter.adjustValue |
Adjusts the Occupancy_Count property when written. When this property is written and the value of the Occupancy_Count_Enable property is FALSE, then the Adjust_Value property shall be set to zero. If Adjust_Value has never been written or the Occupancy_Count_Enable property is FALSE, then this property shall have a value of zero.
A propriedade adjustValue do objeto pulseConverter pode ser lida e escrita utilizando um tag normal (IOTag).
pulseConverter-<endereçoDoObjeto>.adjustValue |
<tipo> = 24 |
<propriedade> = 176 |
Um numero em ponto flutuante de 32 bits.
