program.programLocation |
String that may be used by the application program to indicate its location within the program code, for example, a line number or program label or section name.
A propriedade programLocation do objeto program pode ser lida e escrita utilizando um tag normal (IOTag).
program-<endereçoDoObjeto>.programLocation |
<tipo> = 16 |
<propriedade> = 91 |
