positiveIntegerValue.timeDelay |
Specifies the minimum period of time in seconds that the presentValue must remain outside the band defined by the highLimit and lowLimit properties before a TO_OFFNORMAL event is generated or within the same band, including the deadband property, before a TO_NORMAL event is generated.
A propriedade timeDelay do objeto positiveIntegerValue pode ser lida e escrita utilizando um tag normal (IOTag).
positiveIntegerValue-<endereçoDoObjeto>.timeDelay |
<tipo> = 48 |
<propriedade> = 113 |
