positiveIntegerValue.covIncrement |
Specifies the minimum change in presentValue that will cause a COVNotification to be issued to subscriber COV-clients. This property is required if COV reporting is supported by this object.
A propriedade covIncrement do objeto positiveIntegerValue pode ser lida e escrita utilizando um tag normal (IOTag).
positiveIntegerValue-<endereçoDoObjeto>.covIncrement |
<tipo> = 48 |
<propriedade> = 22 |
