networkSecurity.updateKeySetTimeout |
Indicates the maximum amount of time, in milliseconds, that the device will take to respond to an Update-Key-Set message. This value added to the device APDU_Timeout results in the amount of time that a Key Server shall wait for a Security-Response for an Update-Key-Set message. The use of APDU_Timeout is to allow for network delay; whereas the Update_Key_Set_Timeout provides for the actual time the device will need to apply the keys to its key set.
A propriedade updateKeySetTimeout do objeto networkSecurity pode ser lida e escrita utilizando um tag normal (IOTag).
networkSecurity-<endereçoDoObjeto>.updateKeySetTimeout |
<tipo> = 38 |
<propriedade> = 337 |
Um inteiro de 16 bits (de 0 a 65535).
