networkSecurity.securityPduTimeout |
Specifies the length of time, in milliseconds, the device waits for a security response. For the application TSM to work correctly, this value should be configured to be less than the APDU_Segment_Timeout value in the Device object.
A propriedade securityPduTimeout do objeto networkSecurity pode ser lida e escrita utilizando um tag normal (IOTag).
networkSecurity-<endereçoDoObjeto>.securityPduTimeout |
<tipo> = 38 |
<propriedade> = 334 |
Um inteiro de 16 bits (de 0 a 65535).
