networkSecurity.packetReorderTime |
Specifies the packet reorder time, in milliseconds, used by the device for validating Message Ids. The recommended default value for this property is 500 (0.5 seconds). The property shall be restricted to the range 1 through 3000.
A propriedade packetReorderTime do objeto networkSecurity pode ser lida e escrita utilizando um tag normal (IOTag).
networkSecurity-<endereçoDoObjeto>.packetReorderTime |
<tipo> = 38 |
<propriedade> = 333 |
