networkSecurity.networkAccessSecurityPolicies |
Specifies the security policy for each network directly connected to the device. It specifies the level of security that the device should use for network infrastructure services, such as Who-Is, I-Am, Who-Is-Router, etc. This array shall have 1 entry for each network port. The Port ID field shall correspond to the Port ID of the associated network. For non-routing nodes, this value shall be 0.
A propriedade networkAccessSecurityPolicies do objeto networkSecurity pode ser lida e escrita utilizando um tag normal (IOTag).
networkSecurity-<endereçoDoObjeto>.networkAccessSecurityPolicies |
<tipo> = 38 |
<propriedade> = 332 |
Um string contendo um XML com um valor do tipo <SequenceOfBACnetNetworkSecurityPolicy>.
