networkSecurity.lastKeyServer |
Specifies the device identifier and address of the last Key Server that successfully updated a security key in the device. If no Key Server has updated the keys sets in the device, the deviceidentifier field shall contain 4194303 in the instance part, the network-number field shall be 0, and the mac-address field shall be empty. This property is writable in order to allow a Key Server address to be provided to the secure device before it has received a Device-Master key. This allows the secure device to be directed to the Key Server in a legacy environment where globally broadcast Request-Key-Update messages will not be routed. A device may make this property read-only once a Device-Master key has been received.
A propriedade lastKeyServer do objeto networkSecurity pode ser lida e escrita utilizando um tag bloco de 3 elementos.
networkSecurity-<endereçoDoObjeto>.lastKeyServer |
Size |
3 elementos |
B1: |
B2: |
<tipo> = 38 |
B3: |
B4: |
<propriedade> = 331 |
3 elementos |
Indice |
Nome |
Tipo |
0 |
DeviceIdentifier |
Um texto contendo um identificador de objeto BACnet com a sintaxe '<Tipo>-<Endereço>' (ex: 'analogOutput-345'). |
1 |
DeviceAddress_NetworkNumber |
Um inteiro de 16 bits (de 0 a 65535). |
2 |
DeviceAddress_MacAddress |
Um texto representando uma sequência de dados binários, onde cada byte de dados é representado por um par de caracteres hexadecimais (ex: '0F121A'). |
