networkSecurity.baseDeviceSecurityPolicy |
Specifies the minimum level of security that the device requires allowing client devices to know the level of security to use when communicating with the device. While devices may require higher security levels for some operations, this property shall be readable using the security level defined by this property.
A propriedade baseDeviceSecurityPolicy do objeto networkSecurity pode ser lida e escrita utilizando um tag normal (IOTag).
networkSecurity-<endereçoDoObjeto>.baseDeviceSecurityPolicy |
<tipo> = 38 |
<propriedade> = 327 |
Um inteiro representando uma das opções da enumeração <BACnetSecurityLevel>.
