networkPort.slaveProxyEnable |
Indicates whether (TRUE) or not (FALSE) the device will perform Slave-Proxy functions for this port. This property shall be present and writable if the device is capable of performing the functions of a Slave-Proxy device on this port.
A propriedade slaveProxyEnable do objeto networkPort pode ser lida e escrita utilizando um tag normal (IOTag).
networkPort-<endereçoDoObjeto>.slaveProxyEnable |
<tipo> = 56 |
<propriedade> = 172 |
