networkPort.networkType |
Represents the type of network this Network Port object is representing. When the Protocol_Level is BACNET_APPLICATION, the Network_Type indicates the protocol over which BACnet is operating and implies that the requirements laid out in the appropriate clause are being met. For example, if the Network_Type is IPV4, then the port is operating as a BACnet/IP port.
A propriedade networkType do objeto networkPort pode ser lida e escrita utilizando um tag normal (IOTag).
networkPort-<endereçoDoObjeto>.networkType |
<tipo> = 56 |
<propriedade> = 427 |
Um inteiro representando uma das opções da enumeração <BACnetNetworkType>.
