networkPort.networkInterfaceName |
Identifies the network interface hardware to which this network port is bound. For example, if Network_Type is IPV4, the value of this property identifies the Ethernet hardware interface that this network port is using to communicate.
A propriedade networkInterfaceName do objeto networkPort pode ser lida e escrita utilizando um tag normal (IOTag).
networkPort-<endereçoDoObjeto>.networkInterfaceName |
<tipo> = 56 |
<propriedade> = 424 |
