networkPort.manualSlaveAddressBinding |
Describes the manually configured set of slave devices for which this device is acting as a Slave Proxy. This property shall be present and writable if the device is capable of performing the functions of a Slave-Proxy device on this port.
A propriedade manualSlaveAddressBinding do objeto networkPort pode ser lida e escrita utilizando um tag normal (IOTag).
networkPort-<endereçoDoObjeto>.manualSlaveAddressBinding |
<tipo> = 56 |
<propriedade> = 170 |
Um string contendo um XML com um valor do tipo <SequenceOfBACnetAddressBinding>.
