networkPort.ipv6ZoneIndex |
Contains the zone index for the B/IPv6 link local address when the node supports multiple IPv6 link local addresses. According to RFC 4007, because all link-local addresses in a host have a common prefix, normal routing procedures cannot be used to choose the outgoing interface when sending packets to a link-local destination. A special identifier, known as a zone index, is needed to provide the additional routing information.
A propriedade ipv6ZoneIndex do objeto networkPort pode ser lida e escrita utilizando um tag normal (IOTag).
networkPort-<endereçoDoObjeto>.ipv6ZoneIndex |
<tipo> = 56 |
<propriedade> = 446 |
