networkPort.ipv6DnsServer |
Indicates the IPv6 address of the DNS server used by this network port for Internet host name resolution. The values of this property shall be conveyed with the most significant octet first. If the DNS server addresses are obtained automatically, this property shall be read-only. A value of X'00000000000000000000000000000000' in an array entry indicates that the DNS server address is not available or is not configured.
A propriedade ipv6DnsServer do objeto networkPort pode ser lida e escrita utilizando um tag normal (IOTag).
networkPort-<endereçoDoObjeto>.ipv6DnsServer |
<tipo> = 56 |
<propriedade> = 441 |
Um string contendo um XML com um valor do tipo <SequenceOfOctetString>.
