networkPort.ipv6DhcpLeaseTime |
Indicates the lease time in seconds of the last DHCPv6 lease obtained for the port. If IPv6_Auto_Addressing_Enable is FALSE, or DHCPv6 is not in use, or no lease has been acquired, or the value is unknown, this property shall be 0.
A propriedade ipv6DhcpLeaseTime do objeto networkPort pode ser lida e escrita utilizando um tag normal (IOTag).
networkPort-<endereçoDoObjeto>.ipv6DhcpLeaseTime |
<tipo> = 56 |
<propriedade> = 443 |
