networkPort.ipv6AutoAddressingEnable |
Indicates whether or not this network is configured for automatic address assignment via DHCPv6, Stateless Auto Address Configuration (SLAAC, RFC 4862), or neighbor discovery. A value of TRUE indicates that automatic address assignment is enabled, FALSE indicates it is not.
A propriedade ipv6AutoAddressingEnable do objeto networkPort pode ser lida e escrita utilizando um tag normal (IOTag).
networkPort-<endereçoDoObjeto>.ipv6AutoAddressingEnable |
<tipo> = 56 |
<propriedade> = 442 |
