networkPort.ipDhcpLeaseTime |
Indicates the lease time in seconds of the last DHCP lease obtained for the port. If IP_DHCP_Enable is FALSE, or no lease has been acquired, or the value is unknown, this property shall be 0.
A propriedade ipDhcpLeaseTime do objeto networkPort pode ser lida e escrita utilizando um tag normal (IOTag).
networkPort-<endereçoDoObjeto>.ipDhcpLeaseTime |
<tipo> = 56 |
<propriedade> = 403 |
