networkPort.ipDhcpEnable |
Indicates whether or not this network is configured via DHCP. A value of TRUE indicates that DHCP configuration is enabled, FALSE indicates it is not. This property is required if DHCP configuration is supported by this network port.
A propriedade ipDhcpEnable do objeto networkPort pode ser lida e escrita utilizando um tag normal (IOTag).
networkPort-<endereçoDoObjeto>.ipDhcpEnable |
<tipo> = 56 |
<propriedade> = 402 |
