networkPort.eventMessageTextsConfig |
Contains the character strings which are the basis for the 'Message Text' parameter for the event notifications of TO_OFFNORMAL, TO_FAULT, and TO_NORMAL events, respectively, generated by this object. The character strings may optionally contain proprietary text substitution codes to incorporate dynamic information such as date and time or other information.
A propriedade eventMessageTextsConfig do objeto networkPort pode ser lida e escrita utilizando um tag bloco de 3 elementos.
networkPort-<endereçoDoObjeto>.eventMessageTextsConfig |
Size |
3 elementos |
B1: |
B2: |
<tipo> = 56 |
B3: |
B4: |
<propriedade> = 352 |
3 elementos |
Indice |
Nome |
Tipo |
0 |
elm00 |
Um valor do tipo string (texto). |
1 |
elm01 |
2 |
elm02 |
