networkPort.autoSlaveDiscovery |
Indicates whether (TRUE) or not (FALSE) the device will perform automatic slave detection functions for this port. This property shall be present if the device is capable of performing the functions of a Slave-Proxy device on this port.
A propriedade autoSlaveDiscovery do objeto networkPort pode ser lida e escrita utilizando um tag normal (IOTag).
networkPort-<endereçoDoObjeto>.autoSlaveDiscovery |
<tipo> = 56 |
<propriedade> = 169 |
