networkPort.apduLength |
Indicates the maximum number of octets that may be contained in a single indivisible application protocol data unit sent or received on this port. The value of this property shall be greater than or equal to 50. This property also indicates the maximum number of octets that may be contained in a single individual network service data unit sent or received on this port.
A propriedade apduLength do objeto networkPort pode ser lida e escrita utilizando um tag normal (IOTag).
networkPort-<endereçoDoObjeto>.apduLength |
<tipo> = 56 |
<propriedade> = 399 |
