loadControl.stateDescription |
Contains a string of printable characters whose content is not restricted. The State_Description provides additional information for human operators about the shed state of the Load Control object.
A propriedade stateDescription do objeto loadControl pode ser lida e escrita utilizando um tag normal (IOTag).
loadControl-<endereçoDoObjeto>.stateDescription |
<tipo> = 28 |
<propriedade> = 222 |
