loadControl.shedLevelDescriptions |
Represents a description of the shed levels that the Load Control object can take on. This allows a local configuration tool to provide to a user an understanding of what each shed level in this Load Control object's load shedding algorithm will do. The level at which each shed action will occur can then be configured by writing to the Shed_Levels property.
A propriedade shedLevelDescriptions do objeto loadControl pode ser lida e escrita utilizando um tag normal (IOTag).
loadControl-<endereçoDoObjeto>.shedLevelDescriptions |
<tipo> = 28 |
<propriedade> = 220 |
Um string contendo um XML com um valor do tipo <SequenceOfCharacterString>.
