loadControl.shedDuration |
Indicates the duration of the load shed action, starting at Start_Time. The units for Shed_Duration are minutes. If no shed request is pending or active, Shed_Duration shall be zero. If a load control command has been issued, and execution of the command has completed, Shed_Duration shall be reset by the device to zero.
A propriedade shedDuration do objeto loadControl pode ser lida e escrita utilizando um tag normal (IOTag).
loadControl-<endereçoDoObjeto>.shedDuration |
<tipo> = 28 |
<propriedade> = 219 |
