loadControl.fullDutyBaseline |
Indicates the baseline power consumption value for the sheddable load controlled by this object, if a fixed baseline is used. Shed requests may be made with respect to this baseline, that is, to "percent of baseline" and "amount off baseline". The units of Full_Duty_Baseline are kilowatts.
A propriedade fullDutyBaseline do objeto loadControl pode ser lida e escrita utilizando um tag normal (IOTag).
loadControl-<endereçoDoObjeto>.fullDutyBaseline |
<tipo> = 28 |
<propriedade> = 215 |
Um numero em ponto flutuante de 32 bits.
