loadControl.expectedShedLevel
Indicates the amount of power that the object expects to be able to shed in response to a load shed request. When the object is in the SHED_INACTIVE state, this value shall be equal to the default value of Requested_Shed_Level. When a shed request is pending or active, Expected_Shed_Level shall be equal to the shed level the object expects to be able to achieve at Start_Time. Expected_Shed_Level allows a client (e.g., a master-level Load Control object) to determine if a pending shed request needs to be modified in order to achieve the requested shed level, in the event that Expected_Shed_Level is less than the Requested_Shed_Level. The units for Expected_Shed_Level are the same as the units for Requested_Shed_Level.
A propriedade expectedShedLevel do objeto loadControl pode ser lida e escrita utilizando um tag normal (IOTag).
Parâmetros texto
Propriedade
Valor
ParamDevice
<endereçoDoDispositivo>
ParamItem
loadControl-<endereçoDoObjeto>.expectedShedLevel
Parâmetros numéricos
Propriedade
Valor
N1:
N2:
<tipo> = 28
N3:
<endereçoDoObjeto>
N4:
<propriedade> = 214
Valor do tag
Um dos seguintes tipos de dados:
•Um inteiro de 32 bits sem sinal.
•Um string contendo um XML com um valor do tipo <Unsigned>.
•Um numero em ponto flutuante de 32 bits.
