lift.registeredCarCall |
Represents the lists of currently registered car calls (requests to stop at particular floors using a particular door) for this lift. Each array element represents the list of universal floor numbers for which calls are registered for the door of the car assigned to this array element.
A propriedade registeredCarCall do objeto lift pode ser lida e escrita utilizando um tag normal (IOTag).
lift-<endereçoDoObjeto>.registeredCarCall |
<tipo> = 59 |
<propriedade> = 480 |
Um string contendo um XML com um valor do tipo <SequenceOfBACnetLiftCarCallList>.
