lift.makingCarCall |
Indicates the last car calls written to this property. Writing to this property is equivalent to a passenger requesting that the car stop at the designated floor. Each array element represents the last car call written to this property for the door of the car assigned to this array element. If no car call has been written to an array element, the array element shall indicate a value of zero.
A propriedade makingCarCall do objeto lift pode ser lida e escrita utilizando um tag normal (IOTag).
lift-<endereçoDoObjeto>.makingCarCall |
<tipo> = 59 |
<propriedade> = 475 |
Um string contendo um XML com um valor do tipo <SequenceOfUnsigned8>.
