lift.energyMeter |
Indicates the accumulated energy consumption by the lift. The units shall be kilowatt-hours. When this value reaches 99999 kWh, it shall wrap to a value near zero; the particular value to which it wraps is a local matter. If the Energy_Meter_Ref property is present and initialized (contains an instance other than 4194303), then the Energy_Meter property, if present, shall contain a value of 0.0.
A propriedade energyMeter do objeto lift pode ser lida e escrita utilizando um tag normal (IOTag).
lift-<endereçoDoObjeto>.energyMeter |
<tipo> = 59 |
<propriedade> = 460 |
Um numero em ponto flutuante de 32 bits.
