lifeSafetyZone.reliabilityEvaluationInhibit |
Indicates whether (TRUE) or not (FALSE) reliability-evaluation is disabled in the object. This property is a runtime override that allows temporary disabling of reliability-evaluation. When reliability-evaluation is disabled, the Reliability property shall have the value NO_FAULT_DETECTED unless Out_Of_Service is TRUE and an alternate value has been written to the Reliability property.
A propriedade reliabilityEvaluationInhibit do objeto lifeSafetyZone pode ser lida e escrita utilizando um tag normal (IOTag).
lifeSafetyZone-<endereçoDoObjeto>.reliabilityEvaluationInhibit |
<tipo> = 22 |
<propriedade> = 357 |
