lifeSafetyZone.maintenanceRequired |
Indicates that maintenance is required for one or more of the life safety points that are members of this zone.
A propriedade maintenanceRequired do objeto lifeSafetyZone pode ser lida e escrita utilizando um tag normal (IOTag).
lifeSafetyZone-<endereçoDoObjeto>.maintenanceRequired |
<tipo> = 22 |
<propriedade> = 158 |
