globalGroup.memberStatusFlags |
Contains a logical combination of all the Status_Flags properties contained in the Present_Value. The logical combination means that each of the flags in this property (IN_ALARM, FAULT, OVERRIDDEN, OUT_OF_SERVICE) is TRUE if and only if the corresponding flag is set in any of the Status_Flags property values in the Present_Value property. This property shall be updated whenever new Status_Flags property values are updated in the Present_Value.
A propriedade memberStatusFlags do objeto globalGroup pode ser lida e escrita utilizando um tag bloco de 4 elementos.
globalGroup-<endereçoDoObjeto>.memberStatusFlags |
Size |
4 elementos |
B1: |
B2: |
<tipo> = 26 |
B3: |
B4: |
<propriedade> = 347 |
4 elementos |
Indice |
Nome |
Tipo |
0 |
inAlarm |
Um valor inteiro, onde 0 corresponde a FALSO e qualquer outro valor corresponde a VERDADEIRO. |
1 |
fault |
2 |
overridden |
3 |
outOfService |
