globalGroup.covuPeriod |
Indicates the amount of time in seconds between the periodic unsubscribed COV notifications performed by this object. These COV notifications convey the value of the Present_Value and Member_Status_Flags properties. If the value of COVU_Period is zero, then periodic unsubscribed COV notification messages shall not be transmitted.
A propriedade covuPeriod do objeto globalGroup pode ser lida e escrita utilizando um tag normal (IOTag).
globalGroup-<endereçoDoObjeto>.covuPeriod |
<tipo> = 26 |
<propriedade> = 349 |
