file.archive |
Indicates whether the File object has been saved for historical or backup purposes. This property shall be logical TRUE only if no changes have been made to the file data by internal processes or ghrough File Access Services since the last time the object was archived.
A propriedade archive do objeto file pode ser lida e escrita utilizando um tag normal (IOTag).
file-<endereçoDoObjeto>.archive |
<tipo> = 10 |
<propriedade> = 13 |
