escalator.installationId |
Represents the identification number for the lift represented by this object. This identification number shall be unique for the lift in this group, but might not be otherwise unique for other lifts in the machine room or the building.
A propriedade installationId do objeto escalator pode ser lida e escrita utilizando um tag normal (IOTag).
escalator-<endereçoDoObjeto>.installationId |
<tipo> = 58 |
<propriedade> = 469 |
Um inteiro de 8 bits (0 a 255).
