elevatorGroup.groupMode |
Conveys the operating mode of the group of lifts. This is used to represent some special traffic modes of control of the supervisory controller of a group of lifts. Supervisory controllers are not required to support all modes. Under a special traffic mode, the car dispatching algorithm may be different.
A propriedade groupMode do objeto elevatorGroup pode ser lida e escrita utilizando um tag normal (IOTag).
elevatorGroup-<endereçoDoObjeto>.groupMode |
<tipo> = 57 |
<propriedade> = 467 |
Um inteiro representando uma das opções da enumeração <BACnetLiftGroupMode>.
