device.restoreCompletionTime |
Indicates the amount of time in seconds that the device is allowed to remain unresponsive after the sending of a ReinitializeDevice-ACK at the end of a restore procedure. The restoring device shall either wait or be prepared to encounter communication timeouts during this period.
A propriedade restoreCompletionTime do objeto device pode ser lida e escrita utilizando um tag normal (IOTag).
device-<endereçoDoObjeto>.restoreCompletionTime |
<tipo> = 8 |
<propriedade> = 340 |
Um inteiro de 16 bits (de 0 a 65535).
