device.restartNotificationRecipients |
Used to control the restrictions on which devices, if any, are to be notified when a restart occurs. The value of this property shall be a list of zero or more BACnetRecipients. If the list is of length zero, a device is prohibited from sending a device restart notification. The default value of the property shall be a single entry representing a broadcast on the local network.
A propriedade restartNotificationRecipients do objeto device pode ser lida e escrita utilizando um tag normal (IOTag).
device-<endereçoDoObjeto>.restartNotificationRecipients |
<tipo> = 8 |
<propriedade> = 202 |
Um string contendo um XML com um valor do tipo <SequenceOfBACnetRecipient>.
