device.backupPreparationTime |
Indicates the amount of time in seconds that the device might remain unresponsive after the sending of a ReinitializeDevice-ACK at the start of a backup procedure. The device that initiated the backup shall either wait the period of time specified by this property or be prepared to encounter communication timeouts during this period.
A propriedade backupPreparationTime do objeto device pode ser lida e escrita utilizando um tag normal (IOTag).
device-<endereçoDoObjeto>.backupPreparationTime |
<tipo> = 8 |
<propriedade> = 339 |
Um inteiro de 16 bits (de 0 a 65535).
