device.apduTimeout |
Indicates the amount of time in milliseconds between retransmissions of an APDU requiring acknowledgement for which no acknowledgement has been received.
A propriedade apduTimeout do objeto device pode ser lida e escrita utilizando um tag normal (IOTag).
device-<endereçoDoObjeto>.apduTimeout |
<tipo> = 8 |
<propriedade> = 11 |
