device.activeVtSessions |
Provides a network-visible indication of those virtual terminal sessions (VT-Sessions) that are active at any given time. Whenever a virtual terminal session is created with the VT-Open service, a new entry is added to the Active_VT_Sessions list. Similarly, whenever a VT-session is terminated, the corresponding entry shall be removed from the Active_VT_Sessions list.
A propriedade activeVtSessions do objeto device pode ser lida e escrita utilizando um tag normal (IOTag).
device-<endereçoDoObjeto>.activeVtSessions |
<tipo> = 8 |
<propriedade> = 5 |
Um string contendo um XML com um valor do tipo <SequenceOfBACnetVTSession>.
