command.inProcess |
Set to TRUE when a value is written to the presentValue property. This TRUE value indicates that the Command object has begun processing one of a set of action sequences. Once all of the writes have been attempted by the Command object, the inProcess property is set back to FALSE.
A propriedade inProcess do objeto command pode ser lida e escrita utilizando um tag normal (IOTag).
command-<endereçoDoObjeto>.inProcess |
<tipo> = 7 |
<propriedade> = 47 |
