binaryOutput.changeOfStateCount |
Represents the number of times that the presentValue property has changed state since the changeOfStateCount property was most recently set to a zero value.
A propriedade changeOfStateCount do objeto binaryOutput pode ser lida e escrita utilizando um tag normal (IOTag).
binaryOutput-<endereçoDoObjeto>.changeOfStateCount |
<tipo> = 4 |
<propriedade> = 15 |
