binaryInput.changeOfStateCount |
Represents the number of times that the presentValue property has changed state since the changeOfStateCount property was most recently set to a zero value.
A propriedade changeOfStateCount do objeto binaryInput pode ser lida e escrita utilizando um tag normal (IOTag).
binaryInput-<endereçoDoObjeto>.changeOfStateCount |
<tipo> = 3 |
<propriedade> = 15 |
