accessZone.passbackTimeout |
Specifies the passback timeout in minutes. The timeout is evaluated individually for every credential used to enter the zone. The timeout period for a particular credential begins at the time of successful access to the zone. After the timeout has expired for a particular credential, a passback violation of this credential will no longer be detected. A value of zero or absence of this property indicates passback violations will never time out.
A propriedade passbackTimeout do objeto accessZone pode ser lida e escrita utilizando um tag normal (IOTag).
accessZone-<endereçoDoObjeto>.passbackTimeout |
<tipo> = 36 |
<propriedade> = 301 |
