accessZone.credentialsInZone |
Used to list references to those Access Credential objects that represent credentials assumed to be in this zone. This information may be used to verify whether a specific credential is already in the zone for passback detection purposes. If the zone does not support listing credentials, then this list, if present, shall be empty. It is a local matter as to how this list is updated.
A propriedade credentialsInZone do objeto accessZone pode ser lida e escrita utilizando um tag normal (IOTag).
accessZone-<endereçoDoObjeto>.credentialsInZone |
<tipo> = 36 |
<propriedade> = 266 |
Um string contendo um XML com um valor do tipo <SequenceOfBACnetDeviceObjectReference>.
