accessZone.adjustValue |
Adjusts the Occupancy_Count property when written. When this property is written and the value of the Occupancy_Count_Enable property is FALSE, then the Adjust_Value property shall be set to zero. If Adjust_Value has never been written or the Occupancy_Count_Enable property is FALSE, then this property shall have a value of zero.
A propriedade adjustValue do objeto accessZone pode ser lida e escrita utilizando um tag normal (IOTag).
accessZone-<endereçoDoObjeto>.adjustValue |
<tipo> = 36 |
<propriedade> = 176 |
Um inteiro de 32 bits com sinal.
